09-06-2018 12:52 PM
I am running LabVIEW 2013 SP1 for Mac. I am using the lower-level VI's to send an email because I need attachments, specifically 2 text files. If I try to send a file that is any larger than 54 bytes, then I get Error 363514, with the source:
LabVIEWSMTPClient.lvlib:Send.vi:2280001<APPEND>
<b>Complete call chain:</b>
SendEmail.vi
Why the random tiny size limit, and any way around it? Thanks.
09-06-2018 01:55 PM
If you have time and want to make a small toolkit, you can use .NET to create an SMTP mailer. If you create a .NET constructor node, select the System 2.0 assembly and look for SmtpClient. Look online for the steps needed to do this in a text based language and follow a similar flow within Labview.
