SMTP Email with Attachments Issue
I am running LabVIEW 2013 SP1 for Mac.  I am using the lower-level VI's to send an email because I need attachments, specifically 2 text files.  If I try to send a file that is any larger than 54 bytes, then I get Error 363514, with the source:
LabVIEWSMTPClient.lvlib:Send.vi:2280001<APPEND>
<b>Complete call chain:</b>
   SendEmail.vi
Why the random tiny size limit, and any way around it?  Thanks.
(3,252 Views)
If you have time and want to make a small toolkit, you can use .NET to create an SMTP mailer.  If you create a .NET constructor node, select the System 2.0 assembly and look for SmtpClient.  Look online for the steps needed to do this in a text based language and follow a similar flow within Labview.
aputman
(3,232 Views)
