Runtime front panel
I have a VI I'm trying to modify
When I press run the front panel comes up in the run only mode.
I want to turn that off- how do I do it?
Message 1 of 10
(768 Views)
If you press run, you are in run mode and you cannot edit until you stop..
If your Vi is in run mode without actually running, press ctrl+m to go back to edit mode.
Message 2 of 10
(757 Views)
Thanks let me ask it a different way...
          Normally as the program is running I would see at least the taskbar and some controls... Like stop
Message 3 of 10
(748 Views)
Accepted by LED47
Check VI properties..windows appearance.
(Set it back to default or change your current customization.)
Message 4 of 10
(715 Views)
VIs have "Properties".  Open your Top Level VI, right-click on its icon in the upper right corner and choose "VI Properties".  Make the category "Window Appearance" and choose "Custom", then press "Customize".
Look at the options on the left.  If you turn off "Show Abort" and "Show Run", you won't be able to see these controls on the Front Panel.  Is this the cause of your problem?
Message 5 of 10
(713 Views)
Okay thank you everyone that was the answer
Message 6 of 10
(672 Views)
In this case, it seems "show menu bar" and "show toolbar when running" were turned off. (If the toolbar is not shown, the visibility settings of these buttons (abort, run, etc.) is irrelevant.
Message 7 of 10
(662 Views)
Hi LED,
This is a great mis-conception!
NORMALLY your user should NOT see any "default LabVIEW" taskbar!
Do you see any "IDE taskbar" in other tools like MSWord or Chrome?
Message 8 of 10
(624 Views)
Yes I see what you're saying, Currently I'm in a very early stage of development on this and my users are very few and they're well aware of what we need to do as far as the taskbar Start Stop ETC
Thank you for the input
Message 9 of 10
(617 Views)
During development it should be left at the defaults. Once you built a standalone application, the toolbar should not be there and the menus should be custom.
Message 10 of 10
(610 Views)
