Runtime control flow information
do I have any opportunity to collect control flow information about an executed (or under execution) vi? So can I access anyway to the running environment? I know only for this purpose DET, but I cant access to trace information programmatically, and I am not sure, but as I see, DET does not show all stack trace information (for example if I run a vi from "vi.lib - Clear Error", I cant see that in DET).
Thanks for any help
Balint
(3,924 Views)
If you built your application with Debugging enabled, you can do some things.  In LabVIEW, go to Operate->Debug Application Or Shared Library.  You can even connect to an application on a networked machine.
(3,916 Views)
As I wrote, it is important for me to do that programmatically and I would like to get that information from LabView IDE (not from build application).
(3,897 Views)
If inside the LabVIEW IDE, then highlight execution and probes will get you the information you need.d
(3,890 Views)
Thanks for the hint, it seems it is works to create probes programmatically. Maybe is there any sophisticated approach? I think mainly about a lower level solution (for example which used by labview debugger).
(3,873 Views)
I have not fully explored the properties of Firing Order
There is also, Execution Highlighted Object that returns a ref to the current hightighted object and, you can programatically write to the Highlight execution property..  SO, a bit of playing around may get you closer (especially if you set some breakpoints and control their state programaticallyt)
"Should be" isn't "Is" -Jay
(3,846 Views)
Thanks for the help on this thread too 🙂
I would like to run my analysis on background, so It is not a good way for me 😕 Maybe could I add callback methods to my VI elements, which should be called if that element is currently under execution? Or could I attach some runtime information (tags) to my VI element _without_ instrumentation of my VI?
(3,806 Views)
