Runtime Engine Distribution Licensing (Legal) Issues?
Hi Everyone,
I need an official word from National Instruments on this one.
I've written a program using LabVIEW that I would like to distribute to the public.  It runs in conjunction with a C#-based executable and is installed using the C# program's installer.  Is there any legal/licensing problem with including the LabVIEW Runtime Engine installer with the C# program's installer?
Thanks!
-Yohan
Ramirez Kleinigger Consulting, LLC
http://www.thinkrkc.com/
Message 1 of 8
(5,395 Views)
Accepted by YohanShminge
Hi Yohan,
Thanks for your post and I hope your well.
You can distribute LabVIEW executables freely. There is no need of a license to run executables that only require the Runtime Engine. Other modules such as Real Time do require a Run-Time License. Please see this link for more details: Which Software Requires a Run-Time License?
 Can I ask more about your application - why do you require to distrubte these together?
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 2 of 8
(5,345 Views)
Sounds good, thanks!
It's a somewhat complicated situation.  The software is for a custom data acquisition board which was not originally designed for use with LabVIEW (hence, the C# program).  However, because of the flexibility of LabVIEW, particularly for control applications, we developed a means of interfacing the board with LabVIEW (through .NET).  Now we've got a second set of demonstration applications that's we'd like to include with the main C# program.  Hence, the need for the LabVIEW runtime engine.
Message 3 of 8
(5,339 Views)
Hello-
My company recently developed a GUI for a communications module accessory for our main product line, and we've been arguing as to whether or not we can legally distribute the accomanying run-time engines with our VI or whether they must download them on their own from the website? The run-time engines are LabVIEW 8.0 and VISA 4.5. Thanks!
Morgan Zealear
Manufacturing Engineer
Sierra Instruments
Monterey, CA
Message 4 of 8
(5,081 Views)
One of the options when you create an installer is to include the LabVIEW and VISA runtimes so no, you can distribute them along with your app.
Message 5 of 8
(5,062 Views)
Thanks Dennis - to clarify, did you mean to say "... so YES, you can distribute them..."  or "... so no, you CANNOT distribute them"?
Message 6 of 8
(5,043 Views)
Sorry, should be 'so, yes'. If you couldn't distribute them, then you would not have the option to include them in the installer.
Message 7 of 8
(5,041 Views)
Great, that makes sense!  Thanks!
Message 8 of 8
(5,037 Views)
