graph auto-scroll?
I'm acquiring several hours worth of data during a test.  I am displaying the data on a graph control.  The graph x scale is set up to only show the previous 30 minutes worth of data.  I am periodically saving a snapshot of the graph for logging purposes during the test using the WFGraph.ExportImage method, but my problem is I always see the first 30 minutes.  I want the graph to auto-scroll to the right as I'm acquiring data, but I cannot seem to find a property or method to cause this behavior.  Is there a way to do this that I am not seeing?
David J.
Message 1 of 9
(9,290 Views)
Sounds like you ought to switch to a chart, rather than a graph.
Tim Elsey
Certified LabVIEW Architect
Message 2 of 9
(9,274 Views)
I don't think this would be trivial, as I have several places where I am querying and/or setting properties and methods of the graph, one of which is annotations.  Do charts allow annotations?
Message 3 of 9
(9,255 Views)
Hi David,
Please look at this knowledgebase article--it will answer several of your questions. In addition, using a chart is definitely a better idea. Hope this helps!
Ipshita C.
Message 4 of 9
(9,232 Views)
Hi Ipshita,
I am now currently automatically adding annotations to a graph, making heavy use of it for  post-processing of the data, which your article refers to.  I therefore would not want to switch to a chart, because charts do not support annotations.
So do  you (or anybody) know of a way to get auto-scroll to function in a graph?
David J.
Message Edited by david_jenkinson on 10-02-2009 11:37 AM
Message 5 of 9
(9,220 Views)
I don't know about auto-scrolling, but you can manually scroll using the XScale.Range property node.
Tim Elsey
Message 6 of 9
(9,215 Views)
Hi David,
You can add an X-scroll bar to a chart or graph using the properties. By suto-scroll if you mean auto-scroll the way it is enable for things like Listbox indicators, there is no feature for that available in either a waveform graph or chart.
Ipshita C.
Message 7 of 9
(9,174 Views)
Hi David,
You may consider setting the graph xscale dynamically if you prefer using graph than chart with the property node.
Best,
Bryan
Message 8 of 9
(9,165 Views)
You could use property nodes.
If you have a certain range in mind, for example 200 seconds.
Set x.max to current time
Set x.min to (x.max - 200)
That should 'autoscroll'
Cory K
Message 9 of 9
(9,153 Views)
