Running average - that old chestnut!
Hi all. I have been searching the forum for examples of a boxcar average but can't find anything that suits.
Let's say I have a continuous stream of data coming in at the left and a wire to a waveform chart at the right. I haven't done a vi because it's that simple. I don't know how many data points there will be.
All I want is a black box to insert in the wire that will give me a running average of n points, probably around 5. I don't want the source or the indicator to be inside any loop.
Nearly all of the examples have either a number generator and display inside a loop, or a fixed length array of data points to work on. I just want the data stream coming in, averaged as it goes, and going out. I'm sure it can't be too difficult.
Thanks for any help.
Andy.
Message 1 of 8
(4,314 Views)
Use "mean ptbypt" with a value of 5.
Message 2 of 8
(4,313 Views)
Spoiler
You KNOW it is a simple question if Christian's reply would fit in a tweet.
Smiley Wink
Ben
Message 3 of 8
(4,304 Views)
Actually, mean ptbypt seems to require at least LabVIEW full, but it would be trivial to create a subvi that does the same.
Message 4 of 8
(4,291 Views)
Thank you for that quick reply.
I'm afraid to say I fed you a bum steer, or I didn't explain it properly. The data is coming in packets in the form of a 1D array, of n length, (n is unknown) so I guess I would have to use "Array Size" and then step through it in a loop of n iterations?
Cheers
Message 5 of 8
(4,270 Views)
Accepted by ASH2020
Just place mean ptbypt (and chart) inside an autoindexing for loop. No need to get the size.
Message 6 of 8
(4,264 Views)
I'm using Labview full and it works. Excellent.
Message 7 of 8
(4,263 Views)
Thanks altenbach. Much appreciated.
Cheers
Andy
Message 8 of 8
(4,260 Views)
