Run command prompt as administrator using system exec.vi
I have an application that will not stay open unless it is run through command prompt as an administrator.  I have found a way to add a shortcut to my desktop in order to open it (Administrator: Elevated Command Prompt) but not sure how to programically open this program.  Does anyone have a quick and easy solution to this?  I would like to open the Administrator: Elevated Command Prompt and then start writing my commands.
Thanks!!
-ncm
Message 1 of 18
(25,850 Views)
Hi ncm
See tha image, in the shortcut go to Properties/advanced in select the Run as Administrator option.
I hope it helps you
Message 2 of 18
(25,827 Views)
So the name of my shortcut is Elevated Command Prompt so I did the following with no luch even opening up the file...  any suggestions?
-ncm
Message 3 of 18
(25,798 Views)
You need the extension of the shortcut "Elevated Command Prompt.XX" and also be sure of the path, go to properties/general in the shortcut
Message 4 of 18
(25,795 Views)
Here are my properties, I changed my program to this and the command prompt closes immediatly and doesn't open desktop shortcut (which is technically a command prompt shortcut with administrator rights that I made, I followed:
http://www.sevenforums.com/tutorials/3718-elevated-command-prompt-shortcut.html)
I know it should be something easy that I am missing again but I am stumped.....
-ncm
Message 5 of 18
(25,788 Views)
Accepted by topic author ncm
fix the command line with:   cmd /r "Elevated Command Prompt.lnk"
Message 6 of 18
(25,784 Views)
You have saved the day!!
Thank you very much, I knew it should be simple but just couldn't see the forest cause of the trees Smiley Very Happy
-ncm
Message 7 of 18
(25,780 Views)
Awesome, good luck with your project
Message 8 of 18
(25,777 Views)
That worked exactly how I asked but am finding out that is not what I need.  It opens the program but I want to programmically run commands on the Elevated Command Prompt.  Any ideas on how to do this?  I am trying to do this all programmically so that the user only has to run LabVIEW and not actually type anything into the command prompt.  An example of commands that I want to run in the Elevated Command Prompt are:
cd /
cd "Program Files (x86)"
and other commands.  The reason that I can't use a regular command prompt is that the program will only run out of one with Administrative rights, and that is why I am trying to use the Elevated shortcut because it has administrative priveledges saved in the shortcut.
Any suggestions?
-ncm
Message 9 of 18
(25,755 Views)
Batch file.
Message 10 of 18
(25,748 Views)
