Vision RIO
I want to use the library Vision RIO, LabVIEW 2013 with analog frame grabber AF-1502 on sbRIO-9632.
As I`ve understood, this library works with FPGA, but I`ve never worked with it.
Questions:
  1. Сan you show me some examples or informathion, how use this library?
  2. What can I use it for?
  3. What are the advantages of this library?
Thanks for help.
(4,243 Views)
1) https://www.ni.com/en/shop/choosing-the-right-hardware-for-your-vision-applications/using-vision-rio...
2) https://www.ni.com/en/shop/compactrio/what-are-compactrio-controllers/machine-vision-on-compactrio-a... (see Applications section)
3) https://www.ni.com/en/shop/compactrio/what-are-compactrio-controllers/machine-vision-on-compactrio-a... (see FPGA Image Coprocessing section)
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,216 Views)
