Run 7 while loops in same vi
I have to run 7 threads in Labview 2012. If i run 7 while loops it is taking >50-85%of CPU.
Please let me know if you How to minimize this?
Thanks & Regards,
Harish. G.
(3,510 Views)
You throttle the threads with either a wait block or timed loop structure where appropriate. Of course if you need all those loops processing away at full tilt it's going to cost you 50 to 85%.
(3,500 Views)
Thanks ToeCutter,
But am using wait loop in every while loop. It is not causing any effect.
If you have any example show me 🙂
Thanks & Regards,
Harish. G.
(3,496 Views)
There are 1,000,001 reasons for high CPU usage.  Can you post your code?  What are your different loops doing?  Are you dynamically building arrays?
(3,479 Views)
