Roman Numeral Converter
can someone help me how to make a simple number converter from arabic numbers to roman numerals. I'm using labview for the first time
Message 1 of 14
(2,657 Views)
While you got a solution, you now have three problems to solve:
  1. Understand and develop the algorithm, independent of any programming language.
  2. Implement it in LabVIEW (... not "labview". note the correct letter-case spelling!). For that, you need to study your course notes and maybe also go over the learning resources listed at the top of the forum. You can't just use LabVIEW "for the first time" and do this from scratch! You need to learn the "language" first.
  3. Assuming this is homework, you need to make absolutely sure that you understand every single code detail of the above solution. You teacher will ask you to explain, so be very (very!) prepared. Just submitting a plagiarized solution will not get you very far. Of course you can use my solution to validate your own code.
Message 3 of 14
(2,578 Views)
wiebe@CARYA wrote:
Solved: Change number from Arabic to Roman - NI Community
I'm quite satisfied with my solution in that one, it took me a couple of minutes to figure out what the heck i did back then! 😄
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 14
(2,516 Views)
Add:
4. Figure out how to search the forum. 😉
Message 5 of 14
(2,505 Views)
in google search: site:ni.com [your search terms here]
Jim
Message 6 of 14
(2,474 Views)
I use this all the time. It works better than using the native search function in the forums.
Message 7 of 14
(2,437 Views)
It always has.
Message 8 of 14
(2,431 Views)
Add:
Didn't you start a thread for this?
Hey! Carnac, Over here!
"Should be" isn't "Is" -Jay
Message 9 of 14
(2,425 Views)
Asking my cat works better than using the native search function in the forums. 😂
Message 10 of 14
(2,399 Views)
