Resynchronizing C-Series XNET CAN Modules
Hi community,
I'm using a C-Series XNET NI-9860 to collect CAN data, I start the session on Monday and by Friday the timestamps of the signals have drifted by ~1 second relative to the system clock and can't be trusted anymore.
I've read over some KB articles
https://www.ni.com/docs/en-US/bundle/ni-xnet/page/nixnet/propertysessioninterfacesourceterminalstart...
https://www.ni.com/docs/en-US/bundle/ni-xnet/page/nixnet/synchronization.html
https://www.ni.com/docs/en-US/bundle/ni-xnet/page/nixnet/propertysessioninterfaceoutputstreamtiming....
But I don't understand how to synchronize the HW Clock to my system clock, and since it takes 4 days for the issue to return it's hard to trial.
If I stop then restart the session does this force the clocks to resync?  Or do I need to include a timing frame first?
(2,288 Views)
Accepted by topic author RHryniowski
Regardless of which API is used, XNET will querry the host OS for the current system time when a Interface is started. At that point, the current time is placed into a interface specific timestamp regiseter on the XNET device. The timestamp register will then increment with every tick of the master timebase clock. When a CAN frame is acknowledged, a copy of the timestamp register is attached to the frame and placed into the receive buffer to be read by the XNET API.
Reference: Solved: Re: XNET Timestamp and Windows Timestamp Synchronization
So restarting the interface will force the hardware the query the OS time again.
https://tmesystems.net/
(2,271 Views)
Thanks ZYOng,
The wording in the linked article is a little ambiguous, the commands I am using stop and start the session, the article uses the word interface.
This is the solution I went with, and I'll be watching for a few days to make sure it sticks, but is there a cleaner way?  Stopping and starting the session on the computer I have this deployed to takes ~4 seconds, (a lifetime in production) 😏.
(2,258 Views)
An XNET interface can have more than one session. I am not sure if simply restarting the session will help.
There is a property that allows you to adjust the time without restarting the interface. However, I think it is only supported on PXI/PXIe module.
(2,242 Views)
