Resize height Numeric Control not possible
Because I am using a touch screen for my application the increment/decrement buttons on the numeric control become very small. Is it possible to resize the increment/decrement button is some way?
Best Regards,
Friedrich Völlink
(4,195 Views)
Accepted by FriedrichV
Pop-up and choose customize.
Switch to edit mode and then re-size the buttons.
Ben
(4,190 Views)
Look in the LabVIEW help at "customizing, controls".
It says "1. Right-click a control or indicator you want to customize and select Advanced»Customize from the shortcut menu to display the Control Editor window."
Once you're there, click on the wrench to change modes.  This will allow you to resize/reposition the parts of your control.
Jim
Jim
(4,188 Views)
Rats.  Too slow, again.
 Smiley Sad
Jim
(4,186 Views)
Stoping to get screen shots does me in as well.
Thanks for posting the screen shots I skipped.
Ben
(4,180 Views)
Select the control, and then from the Edit menu "Customize Control".
Click on the leftmost icon, and you can resize the buttons.
Wiebe.
(4,169 Views)
