Reset ZOOM of Intensity Graph
I try to use the built in zoom functionality to define a room of interest. This works fine, but after restarting the Intensity Graph remains zoomed. I already invoke Reinit to default on startup, but the zoom doesn't get reset.
Anyone knows which Node to invoke in order to reset the zoom?
Actor Framework
(1,986 Views)
Accepted by Quiztus2
"reinit to default" is for data. You can "autoscale once" for the x and y axis via a property mode.
If you show the graph palette, there is also a tool to go back.
(1,967 Views)
Unfortunately Autoscale once is not the same as the unscaling button. If your data doesn't fit nice to the scale e.g. your data ends at 80, your scale will go to 100. So a manual rescaling to the actual data size needs to be done.
Actor Framework
(1,900 Views)
Hi Quiztus,
Only when you enable "Loose Fit"! Did you try to change that property?
(1,895 Views)
That helped. It works
Actor Framework
(1,886 Views)
