Report generation toolkit jumping between workbooks
I am having an issue with my VI which I am wondering if anyone has a fix too or workaround.
Basically during my tests I write multiple sets of data to different sheets in Excel using the Report Generation Toolkit.
At the start of my code I open a workbook (template Excel file), I write data to the file at the end of each test for each iteration and then save and close the file at the end.
I have attached a PNG of one of my sub VIs which writes one set of data to one sheet, this could be called numerous times during my code.
The issue I have is that if I am working with a seperate workbook, each time my sub VI runs it will jump to the test results workbook.
I am aware that I do "Get" the workbook in my code and this is why it happens.
Is there a way to call different sheets in a workbook in a VI without affecting the user who is working on a seperate workbook, write data in the background?
I am unsure if it is possible to write data to different sheets in a workbook without using the "Excel Get Worksheet VI" before entering the data.
I also know I could just save all data in arrays and then at the very end write all data to the workbook but this is not a preference
Any information would be gratefully appreciated
Thanks.
(2,935 Views)
Sorry didn't mention any details, I'm using the following:
LabVIEW 2010 SP1,
Report Genration Toolkit for LV 2010,
Office 2010,
Windows XP
Thanks.
(2,911 Views)
Accepted by topic author pmcdonnell
Changed the window state to "No Change" in the new report VI
Seems to have done the trick
(2,904 Views)
