Error 1035 CLSUIP_CreateOverride
Seems to be a bug in LV2011:
I have the error 1035:
In German:
Fehler 1035 bei Eigenschaftsknoten (arg 1) in Apply Configuration For Source Separation.vi->MemberVICreation.lvlib:CLSUIP_Apply New VI Settings.vi->MemberVICreation.lvlib:VIRetooler.lvclass:CLSUIP_CreateNewVI.vi->MemberVICreation.lvlib:VIRetooler.lvclass:CLSUIP_RetoolVI.vi->MemberVICreation.lvlib:CLSUIP_CreateOverride.vi->MemberVICreation.lvlib:CLSUIP_CreateOverride.vi.ProxyCaller
This occured here:
1. added existing HandOver.lvlibp (packed labview class)
2. added new class "TestClass"
3. changed inheritance of class to inherit from HandOver
4. Want to override one function in TestClass
I know there are "Opened VIs" at https://decibel.ni.com/content/docs/DOC-13196
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(3,336 Views)
I have found the solution.
See picture:
The Test.vi in HandOver was added and it was removed from build of library by default:
I think:
THIS SHOULD NOT BE REMOVED BY DEFAULT (if target is lvlibp e.g.)
Eugen Wiebe
Bernstein AG
(3,335 Views)
Hi!
Experienced sth similar, but found the reason to be an Express-VI (don't stone me to death, it's the Structured Error Handler Smiley Wink) call in the parent implementation.
Is this wanted behaviour?
Best Regards
Oli
(3,305 Views)
