Report Generation Toolkit Compatibility with Microsoft Office 2013 and LabVIEW 2011
I design the LabView 2011 Version to test for the solid state device and need to create the test data after this device tested.
When I save the test data in Excel setup after running Laview program, it created an error as "Error - 41007 occurred at NI_report.lvclass:New Report.v -> ...NI reports; You musr have the LabVIEW Report Generation Toolkit for Microsoft Office Installed to create this type of report. The toolkit musr also have an activated license or be in evaluation mode."
Questions: Do I need to install LabView Report Generation Toolkit for Microsoft Office in my computer?. If yes, what is the LabView Report Generation Toolkit for Microsoft Office Version. Where can I find this software?. I use Labview 2011, Window 7, MS 2013 in computer.
Jonathan Tran
Message 1 of 12
(6,279 Views)
What versions of the Report Generation Toolkit support the different versions of Microsoft Office an...
-LabVIEW (Report Generation Toolkit) 2011 supports Microsoft Office XP, 2003, 2007, 2010.
uday
Message 2 of 12
(6,271 Views)
I can not find this software by using this site: -Download LabVIEW 2011 Report Generation Toolkit for Microsoft Office :http://www.ni.com/download/labview-report-generation-toolkit-for-microsoft-office-2011/2572/en/ . When I click this link above, it is an error as Page could not found...
Please help.
Message 3 of 12
(6,262 Views)
Accepted by topic author jotran00
Can you try from this : http://download.ni.com/evaluation/labview/ekit/other/downloader/2011RGT.exe
From this link: http://download.ni.com/evaluation/labview/ekit/other/downloader/
uday
Message 4 of 12
(6,244 Views)
The Report Generation Toolkit is an add-on product that requires a license.  If you need access to Office 2013 (which, logic suggests, came out in 2013), you might want to consider using a version of LabVIEW that is at least "current" with the data structure it needs to support (unless you believe that NI can "predict the future" and build compatibility into LabVIEW 2011 to match products that Microsoft will release two years later).
P.S. -- I am prepared to be proven Wrong on the above assertions, based as they are on "Common Sense" and "Logic" ...
Message 5 of 12
(6,227 Views)
hello, great information and thank you.
Message 6 of 12
(6,213 Views)
If you are interested in interacting with Microsoft Office 2013, why are you working so hard to download an evaluation product that NI says is not compatible with this version of Office?  If you did a little searching of the Web on your own, you would have found both the Report Generation Toolkit Compatibility with Microsoft Office and LabVIEW table that says, clearly, that LabVIEW 2014 is the first version that NI says is compatible with Office 2013.  You could also find NI's download site (or you could go to NI.com, where with a few (obvious) clicks you can get to the Download Site yourself.
Message 7 of 12
(6,200 Views)
I try to develop LabView for reading the source *dbf file.
Is it has the existed function to reading this source *dbf file?
Thanks, Jonathan
Message 8 of 12
(5,230 Views)
Thanks, Jonathan
Message 9 of 12
(5,219 Views)
Thanks, Jonathan
Message 10 of 12
(5,207 Views)
