Removing Frame of array indicator
I would like to Display an Array indicator in the front Panel without the Frame. For Color boxes there is e.g. in "classic" an unframed Color box. I couldn't find the equivalent for Arrays nor can I remove the Frame via property nodes.
Is there a way to do this?
(3,121 Views)
Accepted by volfi
Hi volfi,
for sure there is a way!
Use the brush tool to color the frame transparent: check.png
(3,108 Views)
Use the Control editor and color segments transparent
"Should be" isn't "Is" -Jay
(3,101 Views)
