Remove the labview VI window item from process line
How can i add a costum ini when it is not made yet. Its first made after a build! or what ?
I can add a file under the build 'installer settings' is it there you mean by that ?
HFZ
HFZ
Message 11 of 18
(1,556 Views)
Yes, when I said add it to the installer, I meant add it to the files you have in the installer. Simple and best way is to add it the project.
An ini file can be created without doing a build or running the exe. It's just a text file.
Message 12 of 18
(1,551 Views)
I have moved out all files from the installer map after building the application so i can get the Exe Icon that i want.
So in that way also the costum icon is included in the same file that should be the same op what ?
see the attached
HFZ
HFZ
Message 13 of 18
(1,544 Views)
I don't know what you mean. If you add the ini file to the project, when you select the source files in the installer, you should see something like this.
Message 14 of 18
(1,538 Views)
Hi Dennis, I'm afraid to tell that i've never seen this probertie before,, maybe 'coz i'm using labview 7.1.
Normally i get this Window when building an installer. And there i use the add files, But then where to find the files u're mentioning?
see added file!
HFZ.
HFZ
Message 15 of 18
(1,521 Views)
All done thanks to all help.
HFZ
HFZ
Message 16 of 18
(1,504 Views)
see added file!
HFZ.
That explains the confusion. LabVIEW 8.0 had an enourmous change in the way you build and distribute an application.
Something to keep in mind in the future is that when you are using such an old version of LabVIEW, include that information in the question.
Message 17 of 18
(1,490 Views)
Hi HFZ,
in addition to Dennis' comment: add that information to your signature, so you can't forget to mention your LV version...
Message 18 of 18
(1,485 Views)
