Remove the labview VI window item from process line
Message 1 of 18
(4,633 Views)
I think this discussion can help you...
Norbert
Norbert
Expert: Geometry
Message 2 of 18
(4,625 Views)
HFZ
Message 3 of 18
(4,620 Views)
This is not the case... Because what i want to remove is the Normal Labview running menu and not the VI menu!
Regards
HFZ
HFZ
Message 4 of 18
(4,608 Views)
Accepted by topic author HFZ
That is was is explained there:
add this line to your executables ini file.
hiderootwindow=true
Felix
Message 5 of 18
(4,604 Views)
The solutuion is not optimal,
I want this ' hiderootwindow' to be also opdated when i run the Install setup.exe file for my application.
the Application.ini does not contain the code : hiderootwindow=true. It is not passed trhough when installing the appl.
 How come?
regards
HFZ
HFZ
Message 6 of 18
(4,586 Views)
What do you mean that it does not paas through. I think you missed a step. When doing it this way you will need to create the EXE first. Then put the key in your application.ini file. Then save it and close it. After you do this then build your installer. I have done it this way for a number of apps.
Joe.
"NOTHING IS EVER EASY"
Message 7 of 18
(4,583 Views)
I get the files Setup.ini and DMT Myoflow.ini , ofcourse after the application build is maded.
Then I write the code * : Hiderootwindow=true in the file :  DMT Myoflow.ini , so in the file there only is :
[Myoflow]
hiderootwindow=true
Then i Run the setup.exe to install application. But it do not help.
I've tried to open the configuration file  :DMT Myoflow.ini , in the 'windows programs' map , but could not see this code * in the file.
So i tried to write it there and it worked. But it is not working by automatic.... So i can't make it work for another user ....!
Regards
HFZ
HFZ
Message 8 of 18
(4,570 Views)
Did you include the custom ini file in the installer you created? That's all that you have to do.
Message 9 of 18
(4,568 Views)
When you build the installer be sure to add the custom ini file to the installer build.
Looks like Dennis beat me to it.
Message Edited by Joe_H on 06-15-2009 10:48 AM
Joe.
Message 10 of 18
(4,564 Views)
