ā09-26-2007 04:39 AM
ā09-26-2007 05:00 AM
I don't suppose there is a built in way to do this, but using VI scripting you can go through you hierarchy and call the Remove Structure method on all of these. If you want more details, go look in the LAVA forums scripting forums.
I would probably avoid doing that, however, and I suggest you try to do a find of all the structures and remove them manually.
P.S. For handling different versions of the same project, you should probably check out source code control.
ā09-26-2007 05:03 AM
ā09-26-2007 06:03 AM
ā09-26-2007 08:08 AM
tst suggestion of using SCC is a good one.
Code can be branched into different versions and then merged after testing is completed.
Ben
