add time stamp array into first column of text file
I am writing daq output to a file by using array to spreadsheet string vi then write that to a file but I would like to add a time stamp array into the first column of the text file. How do I do this?
(7,445 Views)
When you use a DAQmx Read, you have the option of returning a waveform data type. This includes time data. If you were to use this and either Export Waveforms to Spreadsheet File or Write Measurement File, this would included. To stick with the regular Write to Spreadsheet File, you would have to create an array of timestamps yourself based on a start time and the sample rate of the DAQ. Then you would convert this and the data array to strings and use the string array type of Write to Spreadsheet instead of the DBL type.
Message Edited by Dennis Knutson on 09-25-2007 01:12 PM
(7,434 Views)
I guess my question is how to put the 2D data array into clumns in the text file starting from the second after converting it to spreadsheet string.
(7,423 Views)
Sorry, I don't understand what you mean. The Write to Spreadsheet File does place data in columns when you wire a 2D array to it. The Array to Spreadsheet String is inside the Write to Spreadsheet File. It would help if you posted your code to get an idea of what you need help with.
(7,417 Views)
I think you re using LV 7.x. If so, please see the attached VI.
- Partha ( CLD until Oct 2027 🙂 )
(7,400 Views)
Thanks a lot!
(7,391 Views)
