Remove NaN
tried but still cant work
Message 31 of 40
(3,071 Views)
Hi nyp,
"tried but still cant work"
What have you tried?
What isn't "working"?
Have you done any debugging?
Have you received any error messages?
How looks your current VI?
Didn't you learn to give meaningful information when asking for help?
Message 32 of 40
(3,048 Views)
sorry!
I tried removing the header lines which i deleted but i am still unable to show the colmn names.
my current vl look like this
Message 33 of 40
(3,039 Views)
Hi nyp,
well, you still delete zero columns beginning from column #7. Don't know what you want to achieve with that operation...
"I tried removing the header lines which i deleted"
First you deleted some lines and then you try to remove them???
See attachment. It uses those header lines to display the column headers.
Sometimes it really helps to read the context help for LabVIEW primitives...
Message 34 of 40
(3,030 Views)
i deleted from row not col.
is it possible to place the "column headers" in to the same arrary of"2000776707" from the vl u shown me?
Message 35 of 40
(3,020 Views)
Hi nyp,
yes, that's passible: Use BuildArray or InsertIntoArray...
Message 36 of 40
(3,014 Views)
how should I remove the NaN for a 2D array?
Message 37 of 40
(2,793 Views)
This is a 2 year old thread unrelated to your question.  There are many other threads that are more pertinent in discussing NaN.
If you remove an NaN from a 2-D array, what you really want it to do?  Do you want to replace it with something else?
Message 38 of 40
(2,785 Views)
I was directed to this thread for the XLR8 toolkit. I want to remove NAN that it creats for blank cells and replace them with Zero.
Message 39 of 40
(2,783 Views)
I don't know how a toolkit directs you to a forum thread.
Look at the comparison palette, you'll see a comparison for "Not a Number".  Use that when indexing through an array to determine whether to replace with zero.
Message 40 of 40
(2,776 Views)
