Remove NaN
still cant work
Message 11 of 40
(3,877 Views)
@TiTou wrote:
you'd be slower on large arrays 😛
Can you explain how it would be slower depending on the array size? Smiley Indifferent
Message 12 of 40
(3,872 Views)
@nyp123 wrote:
still cant work
What is the problem you are facing now?
Message 13 of 40
(3,871 Views)
i took method 1! this is just what i need! Thanks! Heart
now i need to show the column of "2000776707"...any ways?
Message 14 of 40
(3,869 Views)
I suspect you wouldn't see any difference for small arrays (less than 100 000 values) and also the diffence between the 2 methods would tend to be smaller as the number of NaN increases in the array.
I think my solution is quicker because I only test the array once with the "is NaN?" primitive and then my only will only run once for each NaN in the array, whereas your solution will explicitely test each value separately.
That said I could be wrong if the compiler was clever enough to paralelize your for loop Smiley Surprised
Epictetus
Antoine Chalons
Message 15 of 40
(3,859 Views)
Ni nyp,
you already do the filtering by serial number"... What else do you need here?
@TiTou:
You could also get rid of the "IsNaN" comparison and search directly for NaNs. No need for creating a (large) boolean array...
Message 16 of 40
(3,879 Views)
As i am required to show the top column of the array like the one in "2000776729" , i cant show it in the array of "2000776729".
Message 17 of 40
(3,872 Views)
@GerdW wrote:
@TiTou:
when i tested that in LV8.6 it was slower (in the case of large array containing a handfull of NaNs) but I guess you must be right now!
Epictetus
Antoine Chalons
Message 18 of 40
(3,867 Views)
I just made a quick Benchmark for performance.
Message 19 of 40
(3,860 Views)
Hi P Anand,
never benchmark structures running in parallel...
@nyp:
What is a "top column"?
Message 20 of 40
(3,843 Views)
