RemWireLooseEnds
If you have this:
And you press Ctrl-B, you get this:
But if instead if pressing Ctrl-B, you execute paul_cardinale_2-1697498594126.png, you get this:
Gaaa!  I need to remove all broken wires (not just "loose" wires), but apparently such a method doesn't exist.
Message 1 of 15
(2,023 Views)
Accepted by paul_cardinale
Hi Paul,
Use this method instead:
Raphaël.
Message 2 of 15
(1,954 Views)
Be careful though.
If you use OwningVI to get from your diagram to a VI reference, you must close this VI reference!
OwningVI will create a new reference, and it will leak if you don't close it. It will as always close when the top level VI stops...
Message 3 of 15
(1,913 Views)
wiebe@CARYA wrote:
Be careful though.
I think the same is true for a reference to any object other than a GObject.
Message 4 of 15
(1,892 Views)
@paul_a_cardinale wrote:
wiebe@CARYA wrote:
Be careful though.
Could be. But in the GObject hierarchy, there aren't that many (if any?) other than the OwningVI.
OwningVI seems especially easy to overlook. Maybe because it's the property of a GObject, and GObjects don't need to be closed.
Message 5 of 15
(1,829 Views)
I would rather say any object other than a Generic.
Message 6 of 15
(1,817 Views)
Even if the object is an integer? Close the integer?
Message 7 of 15
(1,805 Views)
Well, we were implicitly talking about VI Server references of course.
So any VI Server reference which does not belong to the Generic hierarchy must be closed.
References that belong to the Generic hierarchy do not need to be closed.
Message 8 of 15
(1,784 Views)
But then it's just what Paul said?
Message 9 of 15
(1,772 Views)
"Generic" and "GObject" are not the same, the first is the parent class of the second:
I just said his affirmation can be applied to one level higher in the VI Server hierarchy.
Message 10 of 15
(1,761 Views)
