Regular expression - get longest number from string
I believe it is easy one but I can't get it.Lets say I have a string 'A1_1000' I want to substract the 1000 using regular expression. When I feed Match regular expression I get '1' which is not the longest number. I know other ways of doing that but I want clean solution in one step. Does anybody knows the right regular expression to accomplish that? Thanks!
LV 2011, Win7
Message 1 of 10
(7,025 Views)
Hi ceties,
what do you need? Do you need "A1_" or "A1" or ...? Can you explain a bit more?
Mike
Message 2 of 10
(7,016 Views)
No I need to get the longest number, e.g 1000. A1_1000 ->1000; S2_333->333 and so on. I tried [0-9]+ but it always gets the first number following the first letter. Thanks
LV 2011, Win7
Message 3 of 10
(7,011 Views)
If there's always an underscore _ in front of the number you could search for _[0-9]+ or similar.
Message 4 of 10
(7,008 Views)
It can change it was just an example. But it will always be the longest number i n the string.
LV 2011, Win7
Message 5 of 10
(7,005 Views)
This is the best solution I was able to come with. I am just wondering if there is "smoother way" without the cycle.
LV 2011, Win7
Message 6 of 10
(7,001 Views)
Accepted by ceties
Since multiple checks are required I would tend to beieve that we do have to loop through the possibilities. in this example
I start check at offset "0" into the string for a number. Provided i find a number I check if it is longer that any previous number I found and if so save the new longer number in the shift register.
Have fun!
Ben
Message Edited by Ben on 04-15-2009 09:23 AM
Message 7 of 10
(6,970 Views)
Use "[0-9]*" as your regular expression input.
It will match the longest instance with no loop required.
One thing to note, it will see 1000.023453 as two seperate matches.
If you need to deal with floating point numbers, the iterative method seems to be the most robust.
Greg Sussman
Sr Business Manager A/D/G BU
Message 8 of 10
(6,963 Views)
Umm, nope.  Did you test this?  When you try it against the examples gived (S1_1000), you'll get an empty string, because your match says "0 or more digits" and the first thing that matches that is an empty string because the first character in the string isn't a digit.  If you're seeing in the help a comment about longest match, or greedy matching, what that means is that if you feed it the string 1000, it will get all 4 characters, not just the first one, even though the first digit on its own (or even the empty string as demonstrated above) is a sufficient match.
Message 9 of 10
(6,945 Views)
Thanks you all guys for helping me to tame the regular expression the powerfull and scary entity 🙂
LV 2011, Win7
Message 10 of 10
(6,933 Views)
