Regression solver
Hello.
I´m starting with Labview and I would like tu use the example " Regression sover.vi"  acquiring data from a lvm file. Anybody knows how is it possible? I don´t know where I must to introduce the path. Sorry about me low level.
Thank you very much.
Jon.
(3,321 Views)
are you working with realtime? This is a example for a realtime system.
Well, if you choose in the Frontpanel Write to File or Read to File the case strukture will be executed and the VIs Write or Read to spreadsheet file are called. There you can wire a path or if you dont wire something there will automatically pop up a file dialog, where you can choose the file.
Just execute the vi and you will see how it works.
Greetings, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,282 Views)
Thank you very much RMathew, I have finally got it.
Jon
(3,267 Views)
