load table from xml
Hi all
Please see attach that I send ,, this is vi that write and read from xml file ,, my problem is when I press on load ??
If you can see that I saved a table data  , I want if I press on load bottom  all the data loaded on the screen  in table shape as table control
Who can I do that
Note : press on set limit to save into xml file
(2,971 Views)
Hi
   The problem comes from two general ways. I'm not sure what you really want so I can't rebuild it for you...
First, you ask the for loop to don't execute (you wire 0) you should wire the number of time you want. In addition, if you want to execute it for each line, you should enable indexing on your input xlm to the for loop. Then it will execute as many line it was in the xlm. I can do it, because you can't convert letter to number! So check it, I'll help you later...
Fakstory
(2,962 Views)
Hi elyan
As i can see you still have problems with xml files Smiley Happy
The for loop is not neened. Just delete it.
At write buid an array, so at read you can select 1st element.
At Unflatten from xml, wire a 2D array at "type" input.
You  must have a look at basic Labview tutorials...
(2,933 Views)
I solve it
thanks
(2,928 Views)
