front panel objects not stationary
Hello
I've created a VI for a particular instrument in our lab. There are a number of inputs and outputs associated with it so I arranged them together on the front panel for ease of viewing. However after I saved my VI and opened it again all most of the objects are all jumbled up again. It makes no difference even if I save a new VI. This is really really annoying. One section of the front panel is fine but the other lie over and on top of each other making it a pain to separate. It makes no difference if I move the controls and indicators to their designated spots and lock them, they appear somewhere else when I re-open the VI..
HELP!!!
 Will.
(2,799 Views)
     It seems that you programatically set a location for your controls,... If you place it somewhere it is supposed to be there the next times you open it... moreover if you save it there...
Did you try to place your control and save it, without execute the program...
Nevertheless, without an example it is very difficult to help you...
FakStory
(2,791 Views)
Hi Will,
If you could place the .vi on the forum we can be of more use as to why your having these issues with front panel objects,
(2,765 Views)
