Registration maps?
Sorry, maybe this is a stupid question.
I was going through the idea of maps for a certain feature I'm looking to implement in our software and I just came across the following page on the LV website, it's apparently from LV 2021 and it mentions a "registration map".
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/registration-map/register-vim.html
Now I know I'm not using the most recent LV version (mainly 2015 with some 2019 sprinkled in) but even reading the help on this, I have no idea at all what this is for. Anyone have any ideas?
(2,470 Views)
Don't you find the documentation helpful (in the help)?
Use the Registration Map VIs to create and manipulate registration maps. A registration map is a map between a key and a set of elements with operations to signal when clients register or unregister for one or more services.
Signaling is a weird term for returning a boolean value...
I also have no idea of why a map of sets is so special that there are special VIs for it.
(2,437 Views)
Yes, it is just a map where the value is a set. Use whenever it is useful. 😄
The three registration map VIs just simplify the use by giving more hierarchical information about it, such as if the set was empty for a given key, even if the map entry exists. etc.
(2,417 Views)
Here is a current thread where the registration map may be a good option.  I didn't suggest it since I'm not familiar enough with it either nor did I think the OP is ready for that information.
(2,408 Views)
