Control design & simulation module doesn't work
Hey guys!
I have both LabVIEW 2013 64-bit and 2014 64-bit editions. I downloaded the "Control Design & simulation" module for both versions. However, it doesn't work. When I bring up the "controls" panel in the Front Panel or the "Functions panel in the Block Diagram and click on "Control Design & Simulation" tab, I find it empty. The LabVIEW components window shows that the CD Sim is already installed and acitivated. I attached a picture to explain what's wrong.
Has anybody experienced this before?
Thanks in advance.
Message 1 of 11
(8,859 Views)
I believe the Control Design & Simulation module is only compatible with LabVIEW 32-bit.  This is the case with most LabVIEW modules.  My suggestion would be to install 32-bit LabVIEW on 64-bit Windows, which is the most common configuration for using NI software.
Message 2 of 11
(8,852 Views)
Alright. I'll give it a shot and see what's what. Thanks for your help.
Message 3 of 11
(8,847 Views)
Did you manage to sort this problem as I am in the same situation.
Message 4 of 11
(8,680 Views)
Hi Drew15,
Here is a White Paper that explains LabVIEW bitness compatibility with modules, specifically for Windows 7 OS:
https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
As described there, the Control Design and Simulation module is not compatible with LabVIEW 64-bit software (as are a lot of the other drivers and toolkits). I would recommend installing LabVIEW 32-bit instead!
Message 5 of 11
(8,645 Views)
Hi
   I have installed Labview 2017 32 bit in my PC. It is showing control and Simulation. It contains only PID and Fuzz logic Controllers. It doesn't contain any Simulation, Control Design and System Identity. How can i get them? Capture.JPG
Message 6 of 11
(7,251 Views)
Hi Arjun2002,
You are likely missing the needed software. Most likely you will need the LabVIEW Control Design and Simulation Module. These packages don't come with just LabVIEW.
Zofia
NI Technical Support Engineer
Message 7 of 11
(7,241 Views)
Thank you for your reply. I have downloaded the required software and installed it. Now there is no problem.
Message 8 of 11
(7,225 Views)
this is also my problem what shall i do
Message 9 of 11
(6,242 Views)
Hi hailemicael,
Read message #8 again and do the same…
Message 10 of 11
(6,188 Views)
