Reg. Queue Reference.
Dear All,
If queue reference has not been released explicitly using release queue VI , then weather the queue reference will automatic release by the LabVIEW if owing VI is completed the execution or the queue reference still remains open.
Hemant
Message 1 of 14
(6,848 Views)
When the VI hierarchy that created the queue leaves memory, the queue reference also leaves memory.  This often becomes an issue when code is being dynamically called.
Message 2 of 14
(6,823 Views)
Thanks.
Is this the case all find reference like file reference, controls reference, notifer and like this others.
Hemant
Message 3 of 14
(6,816 Views)
Accepted by LV_COder
@LV_COder wrote:
Thanks.
Hemant
Yes, for most of them. You can find very useful info in this video too, about what kind of references should you close, and which are not (like the Close Ref is a no OP for those): https://youtu.be/LcLyl3Xtp3Y?t=29m26s
Watch the video from 29:25 for reference closing topic, but it is worth to watch the whole anyway...
By the way, do not forget another thing with Queues/Notifiers, etc: if you use a named Notifier for example, and you Obtain Notifier with the same name again to reference it at another place in your code, you must close this second Notifier Reference too (since a new Notifier Refnum will be spawned after the second Obtain Notifier. Or, just use the "force destroy?" option...
("force destroy? indicates whether to destroy the notifier. If FALSE (default) and you want to destroy the notifier, call the Release Notifier function a number of times equal to the number of times you obtained a reference to the notifier or stop all VIs using the notifier reference. If TRUE, the function destroys the notifier and you do not have to call the function multiple times or stop all VIs using the notifier reference.")
Message 4 of 14
(6,795 Views)
Thank you Blokk for the details explanation.
Message 5 of 14
(6,757 Views)
Hello Bolkk.
G object means all the functions like create queue, add, create user event, controls and all permitves right??.
As per the video reference for any object or node, like create queue inherited by GOJECT is not required to close reference, right?
Message 6 of 14
(6,726 Views)
What does "Reg." mean in your message title?  I saw you have that in a different message thread as well.
Message 7 of 14
(6,718 Views)
Reg - Regarding
Message 8 of 14
(6,712 Views)
When I first saw it, I interpreted it as "regulating".
It would be best to leave a superfluous abbreviation like that out of the title.  We already know by the fact fact it is the "subject" of the message what the words following "reg." are for.
Message 9 of 14
(6,695 Views)
Sure, next time i will do.
Can you please help me. What do we mean by G object and whether all the node or function like create queue, add and all the function and controls that ships with LabVIEW falls under the G Object class.
Maybe more helpful if anybody can explain what is the Gobject means here in LabVIEW.
Message 10 of 14
(6,689 Views)
