Reg DAQ module: Very Urgent
I would like to ask some queries related to the NI products.
We are going to design one system to measure the movements of throat and abdomen using 3-axis accelerometer. For that, we have 3 ideas to design the same. Out of these, we preferred the NI LabVIEW.
The following parameters to be considered:
To measure the analog signals with the help of 3-axis accelerometer(sensor)
From the o/p of sensor, we will convert the analog signals to acceleration.
After the above, we are going process the above said requirement.
For this, a separate DAQ module is available. I would be very much grateful if you tell me the cost of the module.
Madhusudhanan
N. Madhusudhanan
(2,487 Views)
Accepted by topic author Madhusudhanan
              The movements are detected by accelerometer and it produce the variation as analog output. So, most probably you will get voltage signal as changes to the input variations.
 Currently, I am working with single axis accelerometer and I am acquiring the data with NI USB 6008/6009 quite comfortably. It all depends on your resolution. You can find more details about these DAQ's here
https://www.ni.com/docs/en-US/bundle/usb-6008-6009-feature/page/user-manual-welcome.html
(2,486 Views)
