Redirecting PFI 0 TO RTSI 0?
my task is rather simple: I want to transfer the signal present on PFI0 of my NI6025 to RTSI0 and then use it to trigger the frame grabber NI1429. All this using CVI and traditional NIDAQ.
I tried e.g.:
Select_Signal ((short)card, ND_IN_START_TRIGGER, ND_PFI_0, ND_LOW_TO_HIGH);
Select_Signal ((short)card, ND_RTSI_0, ND_IN_START_TRIGGER, ND_LOW_TO_HIGH);
BTW: I do not perform any triggered measurement on NIDAQ. Could it be that signal forwarding is only done during triggered acquisition?
Tobi
(3,094 Views)
OK, looks like my Question ended up in the wrong forum. It is not LabView I use. Anyway, the behavior of NIDAQ should be the same. I have to add the following. Actually I do end endless double-buffered acquisition without using any triggers on the NIDAQ card. It seems somehow that the setup of the acquisition resets the trigger mapping. I did not help to set it new after DAQ setup. At least, the usual measurement is not disturbed by this.
Thanks for any comments,
Tobias
(3,084 Views)
Hello!
If you want to route the start trigger of your 6025 to the RTSI-Bus you can simply write:
Select_Signal(deviceNum, ND_RTSI_0, ND_IN_START_TRIGGER, ND_LOW_TO_HIGH);
The signal will automatically go to the line RTSI0 without having to route it manually to PFI0.
Best regards
Ken Tobler
(3,073 Views)
Thanks Ken,
do you know wether the propagation of the the signal is dependent on the acquistion stae or mode of the NI6025.
I have the impression, that the routing is only done when a triggered mode is used. But I have not checked this yet.
Tobi
(3,063 Views)
in the meantime I tried with a very simple program:
#include
int main(int argc, char* argv[]) {
short DAQCard;
int res=0;
Init_DA_Brds (1, &DAQCard);
// route A
res=Select_Signal ((short)1, ND_IN_START_TRIGGER, ND_PFI_0, ND_LOW_TO_HIGH);
// route B
res=Select_Signal ((short)1, ND_RTSI_0, ND_IN_START_TRIGGER, ND_LOW_TO_HIGH);
return 0;
I set a break point at 'return 0' and tried all combinations of A and B by commenting them out or swap. In neither case the signal on PFI0 appeared on RTSI0. Of course the card ID is 1.
I assume that a triggered acquisition must be activated to get the PFI0 propagated?!
Tobias
(3,042 Views)
