Record data at different times
Good afternoon, I have a project that reads several sensors and also communicates with arduino. From labview can turns on several motors, it works perfectly, but I would like to instead of registering every second register every 60 minutes, instead every second. If I put on timer 60000, it takes 60 seconds to turn on the motors.
Forgive my English is not very good. thanks.
Greetings.
I leave the project.
(2,433 Views)
Well your problem is you are not using a proper program architecture.
I would use a simple State Machine in this case with separate states for initialization, monitoring, recording, controlling the motors, etc...
=== Engineer Ambiguously ===
(2,421 Views)
@RTSLVU  ha escrito:
RTSL Thank you very much for responding, you can send me a link or an example pic. Greetings.
(2,395 Views)
Hi joliv,
just open that StateMachine example project coming with LabVIEW!
(2,389 Views)
Hello gerdw
I'll do that, thanks.
Greetings.
Joaquin
(2,355 Views)
