Start FPGA vi on cRIO from Host pc running a host vi
Hi
My labview skills (beginner) are challenged by the following situation:
I want to start a vi on my cRIO which collects data from a FPGA vi from a Host pc.
I have attached a copy of my code. I can start the cRIO vi from the host pc but not the FPGA code.
(1,944 Views)
Accepted by topic author mkstech
Hi mks,
You don't start a VI from your (Windows) computer to run on your cRIO.
The cRIO will run your VI immediatly after booting up - and your VI will wait for commands/communication from your host VI.
Then you should take those training resources offered in the header of the LabVIEW board.
Learn LabVIEW.
Then learn about LabVIEW-RT.
Then learn about LabVIEW-FPGA.
Then start with those example projects coming with LabVIEW. They will explain how to start communication between PC host, RT target and FPGA code!
No, you didn't attach any code. All we got is an image of a small part of your code base…
(1,939 Views)
