03-08-2012 03:28 PM
When createing shared variables to commmunicate between a host Vi and a Real-time target Vi, are those variables in some way addressed to work only on a specific target? I have a four compact fieldpoint units that will all be running the same target VI on the same network. On that same network each cFP target will have a laptop running a host Vi to allow the user to control the a fieldpoint unit. Four compact field point units, four computers. Each pair of computer/fieldpoint units will be running the same VI, just in different locations in the lab. I would start with four projects, one for each fieldpoint system but the bulk of the VI's would be the same including the shared variables names. I then would deploy the target VI to the fieldpoint units. Create executables and installer for each of the host VI's and install them on the specificed computers. Am I going to have issues with the shared variables being the same names for each unit as the send data across the network, or when you add the real-time target to the project, the variables get some sort of tag to be specific between that Target and Host VI?
Thank you for the help
Danny
03-08-2012 04:43 PM
http://zone.ni.com/devzone/cda/tut/p/id/4679
Have you seen the above article? I think if you alias the cFP SV to the host SVE you'll be fine. Dig deep enough into the NI-PSP and you can probably get by with just one project and a config file or FP element to select which Host/cFP pairs up.
