Real-time and shared variables question
When createing shared variables to commmunicate between a host Vi and a Real-time target Vi, are those variables in some way addressed to work only on a specific target?  I have a four compact fieldpoint units that will all be running the same target VI on the same network.  On that same network each cFP target will have a laptop running a host Vi to allow the user to control the a fieldpoint unit.  Four compact field point units, four computers.  Each pair of computer/fieldpoint units will be running the same VI, just in different locations in the lab. I would start with four projects, one for each fieldpoint system but the bulk of the VI's would be the same including the shared variables names.  I then would deploy the target VI to the fieldpoint units.  Create executables and installer for each of the  host VI's and install them on the specificed computers.  Am I going to have issues with the shared variables being the same names for each unit as the send data across the network, or when you add the real-time target to the project, the variables get some sort of tag to be specific between that Target and Host VI?
Thank you for the help
Danny
Danny
(2,406 Views)
http://zone.ni.com/devzone/cda/tut/p/id/4679
Have you seen the above article?  I think if you alias the cFP SV to the host SVE you'll be fine.  Dig deep enough into the NI-PSP and you can probably get by with just one project and a config file or FP element to select which Host/cFP pairs up.
--Using LV8.2, 8.6, 2009, 2012--
(2,402 Views)
