Reading values from a Matrix
@AymanB95 wrote:
P.S.: i cant put the property node in the autoindexing loop, in the big VI that woukld be too complicated 😞
That means you are doing something wrong. Since the property only accepts a single number, it cannot accept an array as you currently do and that probably would not make any logical sense.. (there is a reason the property is named "position" and not "positions".)
Message 11 of 18
(1,722 Views)
Accepted by topic author AymanB95
Hi Ayman,
That node belongs into the FOR loop. Point.
When it is "complicated in the big VI" then your "big VI" needs some refactoring!
Message 12 of 18
(1,718 Views)
Thank you for your reply.
Im of course aware that the node only takes ONE position at a time. My goal is to make the node take the values of X from the array one after one until the end of the Array
Message 13 of 18
(1,715 Views)
Hi Ayman,
Place that property node inside the FOR loop and you're done!
Like this:
Message 14 of 18
(1,712 Views)
Okay thank you sir
Message 15 of 18
(1,705 Views)
I recreated your VI example in my version of LV. Gerd is correct that you can place the property node inside the for loop and be done. Or you can also use a numeric conversion to whatever byte you need an I64 in your case. In my attached example, I left the node outside the for loop but wired the conversion piece inside it, I used a slider so I could watch it switch through the various numbers generated throughout the code. I also placed the entirety of the code inside a while loop, so the VI runs til the array is complete. I am learning as well and any corrections and or recommendations as to what I chose to do are always welcome.
Creig Mills
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 16 of 18
(1,687 Views)
Thank you so much, but the conversion wouldnt solve the problem. The slide you made in this VI only reads the last value in the Array (the last row) and not all values (row for row). But thank you again 🙂
Message 17 of 18
(1,658 Views)
I corrected what I was doing, after having re read all of your post. I believe this vi does what you want now. I multiplied the random number generator value by 250 for scaling purposes. In lieu of the index array, I placed another for loop. I wired indicators to both of those for loops to show the movement through rows and columns. As the slide reads them one and after another. Hopefully this works for you.
Creig Mills
Culverson.com
Message 18 of 18
(1,646 Views)
