Can someone please please help? I combined arduino and MCC DAQ? Problem reading analog voltage (see attached VI)
I am using arduino to output the PWM and MCC DAQ to read the update analog voltage. It was working at some point. So every time I would change PWM, the analog voltage would change accordingly. Now, the voltage is not updating anymore when I change the PWM.
So for 100% duty cycle - I am expecting 0.095. I don't have any problem with this. The only problem that I am having is when I changed it to lower duty cycle, I kept getting 0.095 as you can see. I tried to throw an invoke node to reinitialize values, but it's not working.
Good  analog value
Wrong analog value
(1,205 Views)
Accepted by topic author GRCK5000
Hi GRCK,
Do you get any errors? Did you debug your VI (using probes or additional indicators)?
Keep in mind: we don't have your hardware, neither your Arduino, no ULx device and not your UUT!
You need to provide a lot more information to expect/get any usable help…
What's the point of setting the DutyCycle increment property so often?
Why don't you place PWM output and AI reading into just one loop?
(1,174 Views)
Hi GerdW,
Yes, sorry about the duty cycle increment. I really don't need it.
Thanks a lot! it worked.  when I tried to put them in one loop last time, it didn't. So I thought it was because I was using two different libraries. Now, it's working fine as expected. You are awesome!!!! You deserve a 1000 kudos.
(1,162 Views)
