Reading serial from 3rd party device
I try to communicate with a 3rd party device, a smoke tester for trucks, using serial read in LabView. I've attached the command parameters in dokument. I use the diesel parameters on page 9. I don't manage to get out sensible information. There are no bytes at port when running the program. But one time I had 6 bytes at port running the code. This only happened once. See picture in attachment. I'va also attached the code.
Can anyone help me?
Message 1 of 24
(4,585 Views)
Hi paalbrok,
the manual says you need to use a baudrate of 9600, but you use 19200 in your VI…
Message 2 of 24
(4,570 Views)
Hello GerdW,
Thanks for your reply
I get no data with 9600 baudrate as well. The problem has to be something else.
br,
paalbrok
Message 3 of 24
(4,562 Views)
What command are you trying to send and receive the response?
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
Message 4 of 24
(4,550 Views)
As you see from attached picture, I've used the 0x64 0x9C HEX command which read out the parameters from the device. It doesn't work.
br,
paalbrok
Message 5 of 24
(4,543 Views)
Hi paalbrok,
no, you don't send those hex data. You send a string containing the ASCII chars "649C", followed by "\r" as it seems!
Set the display mode of those string constants to "hex"…
Message 6 of 24
(4,533 Views)
Hello GerdW,
649C is HEX. I send this and recieve no data. \r is 0D in HEX. I try to send different strings "649C\r" and "649C 0D" using HEX display mode. Also \r\n in the end. Nothing works.. Do you have any ideas?
Can you modify my code with correct string constant if I misunderstand?
br,
paalbrok
Message 7 of 24
(4,509 Views)
If it is really in Hex, you are expected to see the following, when reading highlighted string. It will not show you 649C, as in your screenshot.
Message 8 of 24
(4,504 Views)
Hi paalbrok,
arevhamb is right - that's why I suggested to check your string constants!
Message 9 of 24
(4,494 Views)
When communicating with an unknown device, MAX is your friend.  With MAX, you can quickly set up your Serial Port for (almost) any Baud Rate, Parity, Bit length, etc.  Don't neglect the Parity setting -- we recently attempted to establish communication with a serial device, knew we had the right Baud rate, and were using the usual N-8-1 bit configuration.  Nothing.  Just for fun, we tried O-7-1 -- got garbled text.  E-7-1 was what we needed ...  Hooray for MAX!
Message 10 of 24
(4,449 Views)
