How to Plot the Envelope of the resulting signal of 2 random signal?
Firstly i add up two random generated siganl to get a final signal.
then,how can i get the envelope of the final signal?and plot it in a graph?
thank you
like the picture i attached.
Message 1 of 18
(5,705 Views)
Hi Ying, instead of attaching a picture taken from your phone, why not upload the actual code? Is it proprietary?
Message 2 of 18
(5,685 Views)
Sorry,im a new user in labview,here is the code
Message 3 of 18
(5,646 Views)
Unfortunately I am using LV 2014 so I cannot view it. Can you backsave it? (Maybe to 2012 so more people can see)
Message 4 of 18
(5,639 Views)
Like this?
Message 5 of 18
(5,631 Views)
Using Hilbert transforms you can get the required envelop. Just it returns only upper envelope. You need some more coding to get also lower envelope.
Do you need something like this?
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
Message 6 of 18
(5,613 Views)
Yes! can u share the code ?
Message 7 of 18
(5,605 Views)
Accepted by topic author Ying88827
Please find attached!
Arev
Message 8 of 18
(5,591 Views)
Thank you so much!
Message 9 of 18
(5,584 Views)
Sorry, I have question again....If I change one of the signal into sawtooth or square wave, the envelope is not that smooth and some peak it detect is not accurate. So how can I fix it?
Message 10 of 18
(5,518 Views)
