Reading HTML Code From a Web Site with login
Looks reasonable - but I don't know if it's correct because only the developers of the website can answer that question 🙂
As I said before - you say it "doesn't work" - but what do you mean - do you get an error? What response headers/body do you get?
(blog)
Message 11 of 20
(47,454 Views)
As output no value .
body = empty .
headers = empty.
error: 363506
LabVIEWHTTPClient.lvlib:POSTBuffer.vi:6120001<APPEND>
<b>Complete call chain:</b>
     WebService_POST.vi
Message 12 of 20
(47,448 Views)
Is there an error message that comes with it? Normally you get more information than just the code and the error source which would indicate the reason for the error. These are basic steps for troubleshooting issues with your LabVIEW code.
Right click on the error indicator and select 'explain error':
(blog)
Message 13 of 20
(47,440 Views)
The problem seems the certificate, this error:
LabVIEW:  The certificate path or CA information of the local host is invalid.
In CONFIG SSL function should I put both certificates ( CA and CLIENT ) or one is sufficient ? which? and where is it ?
I'm sorry for the many questions but I can not find information.
THANK YOU
Message 14 of 20
(47,428 Views)
Message 15 of 20
(47,427 Views)
Did you try my earlier suggestion of turning off the verify server option of the configure SSL VI? If you do that, you shouldn't need to wire anything to the certificates/key inputs (as these are only needed for verifying the server against either a self-signed or a trusted certificate).
(blog)
Message 16 of 20
(47,419 Views)
I tried it with OFF verify server and any attached certificate , it returns a header but empty body and no errors .
Message 17 of 20
(47,417 Views)
Just want to throw in here that it looks like aliexpress has a documented public api: http://portals.aliexpress.com/help/help_center_API.html?spm=a2g01.8078014.0.5.ZpKuEo
It shows you how to build up the urls and documents input parameters, output parameters, errors, etc.
If the API provides the data you are looking for it will probably be significantly easier to get the data you want. The public API also has the benefit of being supported by the company.
Milan
Message 18 of 20
(47,404 Views)
And what is in the headers?
(blog)
Message 19 of 20
(47,403 Views)
HTTP/1.1 302 Found
Date: Tue, 06 Sep 2016 16:23:24 GMT
Content-Length: 0
Connection: keep-alive
Set-Cookie: ali_apache_id=10.182.248.33.1473179004909.271347.3; path=/; domain=.aliexpress.com; expires=Wed, 30-Nov-2084 01:01:01 GMT
Server: Apache-Coyote/1.1
P3P: CP="CAO PSA OUR"
Location: http://sec.aliexpress.com/query.htm?smApp=globalsearch&smPolicy=globalsearch-globalsearch_category-a...
Content-Language: en-US
Strict-Transport-Security: max-age=0
Timing-Allow-Origin: *
Message 20 of 20
(47,398 Views)
