Read from tab delimitted text file and write to csv
Do your own work!  This is the second extended post this month about Spreadsheet Files.  I suggest you spend time with the LabVIEW Help system, as well as researching File operations in LabVIEW.  Indeed, such a search turned up multiple hits, several articles that discuss multiple ways to write comma-separated data.
You should also do some reading about Comma-separated-variable files.  Maybe you would learn that there are no cells involved in Write-to-spreadsheet -- it is simply a text file, which has lines and characters, but not cells.  Once you put some of your effort into your problems you should be able to come up with at least 3 similar-but-different ways to handle your situation.
Understanding the nature of the CSV format should also provide the (almost trivial) answer (or answers -- there are several ways to do this) for how to read everything except the first line of a CSV file.  [Hint -- suppose you read everything.  How do you get rid of the first line?  Pretend that you've passed the CLAD exam ...].
Message 11 of 11
(996 Views)
