Read RPM using ni-usb 6009
I have NI-USB 6009, optocoupler sensor and rotary encoder to read RPM. My question is How can I do this in labview to read RPM ?
if anyone can please help me out with this. if you have example, it's more better. because I'm beginner in labview.
regard
Okky
Message 1 of 14
(6,290 Views)
Check out this USB6009 + Encoder.
There are limitations though. You can not sense direction.
PBP
Labview 6.1 - 2019
Message 2 of 14
(6,286 Views)
ok thank's. but I have a problem how to create the VI
regard
okky
Message 3 of 14
(6,272 Views)
hi okky.septa.c,
Check this .USB-6008 and USB-6009 RPM Reading with Counter (Frequency)
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 4 of 14
(6,251 Views)
when I used this VI, the count is going up, up and up. I need when I stop, the RPM in zero condition.
so, do you have solution for me ?
Message 5 of 14
(6,191 Views)
Hi okky,
read the manual of your USB6009: it clearly says the counter can only count-up!
But what is your problem anymway: to calc RPM you need to get differences of your counter…
So when you stop your VI the last RPM value should be zero? Even when the machine is still rotating? I don't get this…
Quick&dirty: write a zero to your RPM indicator when you stop the VI…
Message 6 of 14
(6,182 Views)
I would like to know if NI USB 6009 needs an external power source for generating signals or is it good enough when connected to the PC ?
Message 7 of 14
(5,858 Views)
Hi Vishnu,
you don't need an external power source…
Message 8 of 14
(5,854 Views)
Thanks for the quick reply.
I'm supposed to record pressures from 4  Pressure switches and 3 piston detectors as well as generate signals to stop the pump when the pressure exceeds the limit.
I have very basic knowledge about this. It would be great if you can offer some advice here.
Thank you
Message 9 of 14
(5,848 Views)
Here's the Testrig
Message 10 of 14
(5,844 Views)
