Read From Measurement File
I am trying to read a measurment file through the read from measurment file VI but i keep getting the same error:
this is the error:
LabVIEW:  End of file encountered.
NI-488:  Invalid argument or arguments.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 1 of 19
(6,428 Views)
Harold,
Can you please post your lvm file and the vi. you are using to read it with.  Regards, -SS
Message 2 of 19
(6,413 Views)
Hi Harold,
beside your other problem:
You can switch on "digital display" of those tank indicators. That way you don't need additional numerical indicators to show the same valueSmiley Wink
And using a simple "less" operation from comparison palette instead of an express vi makes the vi much more readable (can't hide the second operator here)!
Message Edited by GerdW on 07-18-2008 07:13 PM
Message 3 of 19
(6,404 Views)
the forum will not let me put a .lvm file on the
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 19
(6,390 Views)
the forum won't let me put a .lvm file on it
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 5 of 19
(6,389 Views)
You are correct the Forum GOD was not happy:)  Rename as *.txt and resend.  Congratulations you found a forum bug!    -SS
Message Edited by ShotSimon on 07-18-2008 02:57 PM
Message 6 of 19
(6,384 Views)
here it is as text
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 7 of 19
(6,374 Views)
here it is as text
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 19
(6,374 Views)
here it is as text
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 19
(6,374 Views)
here it is as text
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 10 of 19
(6,374 Views)
