I always use a lot of dynamic VI's in my projects, and sometimes I need to
pass parameters to them. I use Set Value methods.
One problem is that when you build an executable, the application builder
(AB) removes the panels by default, and the Set Value method will fail... I
know you can change the AB settings, but I was getting tired of that (and
had some free time). I also know you can change the VI properties so AB
won't remove the front panel...
But I started looking for things that tells the AB not to remove the front
panel.
I found out that the FP won't be removed when the VI has an event structure.
And it turns out that this works even if you put the event structure in a
disable case!
I'm pretty sure this isn't supposed to happen. I'm not so sure if it's
usefull since it might change over versions (I use 8.5.1), but I thought I'd
share it anyway...
Wiebe.
