Re: how can i extract the peak values found on the waveform graph
hi
gud evng. iam new to ni lab view software and iam working on it for ambient measurements so for that I started VI by giving known sinusoidal input and then later I observed that output waveform in graph. But I want to export that peak values to list how can I get that could you please help me in getting the list.
thankyou
Message 1 of 10
(4,700 Views)
Try using a for loop and put a threshold, if the value is above threshold then send it out of the loop using conditional terminal.
CLD Using LabVIEW since 2013
Message 2 of 10
(4,686 Views)
ya i got dat sir by using peak detector block by setting threshold value for it and i still having one doubt dat in real time measurements we cannot set the threshold level so I want the peak list values without keeping the threshold value so is this possible???? if s dn hw???
iam dng this measurement my considering raw data from FSL18 and giving that to peakdetector
Message 3 of 10
(4,649 Views)
yr txt s vry rdbl,
prhps y shld wrt prpr nglsh
on the block diagram hit CTRL+Space and search for "peak", there is a "Peak Detector.vi",
wire your data and give it a threshold, then you will get the x-values for the peaks.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 4 of 10
(4,643 Views)
but i want the output peak without giving input threshold value
Message 5 of 10
(4,632 Views)
sounds like you want to know the maximum,
hit ctrl+space and search for max
Message 6 of 10
(4,629 Views)
yes sir i want d maximum values bt i tried yours ctrl+space and that max block is not working can u give me some other help please
Message 7 of 10
(4,622 Views)
Send us what you tried that didn't work.  Otherwise we won't be able to point to your error.
Message 8 of 10
(4,610 Views)
please find the attachment this is what i have tried and please help me to get the peak values without the input threshold value
Message 9 of 10
(4,602 Views)
please read this
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
this will help you help us help you
regards
Message 10 of 10
(4,589 Views)
