Re: fuzzy logic - Labview
Sir how to create program fuzzy logic  on sbrio?
why my fuzzy logic file path can't detect when i run my real time vi?
Message 1 of 9
(4,136 Views)
Hi zrohman,
Most often the problem is: the sbRIO doesn't has access to your PCs harddrive!
The sbRIO is a computer on its own! You  need to transfer any needed data/files to your sbRIO while deploying your software…
Message 2 of 9
(4,131 Views)
So how to transfer my fuzzy logic file/data path from my pc drive to sbrio?
Please tell me sir, 🙂
Message 3 of 9
(4,072 Views)
Hi zrohman,
when you build your RT exe you include all data files in the build (as additional file).
Those additional data files will (by default) be stored in the data subfolder next to the RTEXE. Load them from that path…
Message 4 of 9
(4,062 Views)
this is my front panel, still can't access my fuzzy logic files
Message 5 of 9
(4,044 Views)
Hi zrohman,
did you deploy that file together with your RTEXE to the sbRIO?
You still don't try to load this file from the "data" subfolder as mentioned before!?
Message 6 of 9
(4,038 Views)
To be honest I am very layman using sbrio ni labview, i do not understand what you say sir, huh huh 😞
could you explain; guide; tell; me step by step to create fuzzy logic on sbrio with picture?
Message 7 of 9
(4,034 Views)
Hi zrohman,
create a new executable for your sbRIO. When doing so add the data file as additional file to the build.
The AppBuilder will show you the file path, where that data file is stored on your sbRIO…
Did you read all those free resources on cRIO/sbRIO for beginners?
Message 8 of 9
(4,027 Views)
I know its an old post, but still...
-suppose you can ftp into your controller? Then place the .fs file in the same folder as where you found the other files?
-if you set as file path ..\fuzzy.fs  then it should work? Found even with LV2023 the .fs file needs to sit in the same folder as the vi that is using it. So this is what ..\ does, gets the file from the same folder.
Message 9 of 9
(1,700 Views)
