ā07-16-2017 11:17 PM
Sir how to create program fuzzy logic on sbrio?
why my fuzzy logic file path can't detect when i run my real time vi?
ā07-17-2017 02:38 AM
Hi zrohman,
Most often the problem is: the sbRIO doesn't has access to your PCs harddrive!
The sbRIO is a computer on its own! You need to transfer any needed data/files to your sbRIO while deploying your softwareā¦
ā07-24-2017 06:48 PM
So how to transfer my fuzzy logic file/data path from my pc drive to sbrio?
Please tell me sir, š
ā07-25-2017 01:34 AM
Hi zrohman,
when you build your RT exe you include all data files in the build (as additional file).
Those additional data files will (by default) be stored in the data subfolder next to the RTEXE. Load them from that pathā¦
ā07-26-2017 03:02 AM
this is my front panel, still can't access my fuzzy logic files
ā07-26-2017 03:29 AM
ā07-26-2017 04:06 AM
To be honest I am very layman using sbrio ni labview, i do not understand what you say sir, huh huh š
could you explain; guide; tell; me step by step to create fuzzy logic on sbrio with picture?
ā07-26-2017
06:06 AM
- last edited on
ā09-19-2025
01:30 PM
by
Content Cleaner
Hi zrohman,
create a new executable for your sbRIO. When doing so add the data file as additional file to the build.
The AppBuilder will show you the file path, where that data file is stored on your sbRIOā¦
Did you read all those free resources on cRIO/sbRIO for beginners?
ā11-12-2023 06:46 PM
I know its an old post, but still...
-suppose you can ftp into your controller? Then place the .fs file in the same folder as where you found the other files?
-if you set as file path ..\fuzzy.fs then it should work? Found even with LV2023 the .fs file needs to sit in the same folder as the vi that is using it. So this is what ..\ does, gets the file from the same folder.
